iprog+plus can bus adaptor scenic2 dashboard pin
asliyucegsm
my friend
Can-L and Can-H on the scenic indicator table, how should I connect them to the indicator pins on the adapter, can you help me, thank you
İPROG+PLUS CLONE
    99,3 КБ · Просмотры: 18
    679,5 КБ · Просмотры: 19
    1,4 МБ · Просмотры: 19
You need emulation tool.
Mayby resistor 120 Ohm, to can.
Hello friends, the problem is solved and it works fine.
    1,6 МБ · Просмотры: 18
