Hi, im trying to program a refurbished 6T40 TCM using DPS. I changed the VIN and programmed the OS and calibration files. But the VIN have not changed after programming. How can i change the VIN on this 6T40 TCM.
I dont think your answer above is correct. The topic is to change the VIN on a 6T40 using DPS. It will be great f there is any one who can guide me to this.
As far as I know If you using online SPS you need to finish first procedure of deleting module from car with reprogram it to null state like it was new
Only after that you can program it to another car
And reprogram it to new with online SPS only possible if you have another modules to emulate whole car (like BCM ECM and so on -its antitheft feature)
This operation takes time (usually 30 min) -so if you stealing it it will rises chances that you will be caught
