Will BKP engine run on BKD software?
  • Автор темы Автор темы Unq
Unq
Hello friends!
I apologize for writing to you in English, but my knowledge of Russian is not enough to make me understandable.
I have a situation here.
I received a car with an error on the EGR.
The car is a Passat 2007 2.0 diesel with BKP code engine. This car has an electric EGR with position sensor, but in the live values we found only EGR values calculated indirectly from the volume of air measured by MAF.
When I searched the engine ECU, I found that it is actually a computer for the BKC engine, but the BKC engines are 1.9 diesel. I read the software in the computer and found that it is for BKD engine.
So we have a BKP patient, with a BKC ECU harware, that contains BKD software ...
Now the problem is that BKD motors have vacuum EGR and not electrically driven, hence the EGR error.
My question is:
Will removing EGR from BKD software solve my BKP engine problem? My estimate is yes, but I want to be 100% sure because I don't know and if the MAF calculation algorithm will be affected.
