Программа Xentry Passthru 09.2023
  • Автор темы Автор темы fortovuy
Buenas, alguien puede poner un enlace en mega o por torrent con xentry passtru 09.2023. No lo encuentro por ningún sitio.
Muchas gracias
Загружаю на mega.nz xentry 09.2023 для karlezero. А то вижу что человек просит и никто не хочет ему помочь.
Uploading to mega.nz xentry 09.2023 I'll post it now. For Karlezero. I see a person asking and no one wants to help him.
Ссылка будет действительной 10дней, пользуйтесь моментом
Это ссылка на xentry 09.2023
User: xentry
Password: 123456
BATCH INSTALLATION INSTRUCTIONS:
1. INSTALL XPT 23.9.3 or XDOS 23.9.4 using the DEFAULT INSTALL PATH and when prompted to reboot your device, select NO (Daimler download URLs for XPT/XDOS can be found in the "XENTRY.Download.URLs" folder).
2. RUN "PART1_Run-As-Admin.bat" as ADMINISTRATOR, follow the steps, then REBOOT YOUR DEVICE when the batch process tells you to.
3. ConfigAssist should automatically start after rebooting the device, however if it does not, RUN ConfigAssist and proceed to the START-UP KEY step, then you will need to use 'XENTRY Advanced Keygen 1.1' to generate a LONG START-UP KEY and complete the activation using the 'MANUAL' button in ConfigAssist (I would recommend running Keygen in a SANDBOX or VIRTUAL MACHINE).
Once ConfigAssist has completed activation, a file named 'lic_key_2.dat' will appear in 'C:\ProgramData\LicDir' (this file will not appear if activation was not completed successfully, so you can check if this file exists before proceeding to the next step if you wish).
4. RUN 'PART2_Run-As-Admin.bat' as ADMINISTRATOR and follow the instructions.
5. Enjoy XENTRY XPT/XDOS :)
ADDITIONAL PACKAGE INSTALLERS:
C003 Error Fix:
This is for the C003 authentication error that occurs when trying to diagnose/read modules on models that require a valid ZenZefi certificate installed.
Устанавливай строго по этой инструкции и всё получится.
Install strictly according to these instructions and everything will work out.
User: xentry
Password: 123456
C003 Error Fix:
XPT installed and tested on a Mercedes W212 successfully. Many thanks for sharing.
User: xentry
Password: 123456
C003 Error Fix:
Приветствую! А можно перезалить файлы патчера, пожалуйста? Нашел ссылку на второй странице данной ветки, но она уже, к сожалению, йок :(
Патчер Пожалуйста
xentry 09.2023
Патчер одним файлом и без никаких манипуляций? Даже кейген не нужен?
Да. Читайте инструкцию по установке, выше.
Сорри за беспокойство, но насколько я понимаю, инструкция выше идёт для патч-пака, который был выложен на второй странице этой ветки (ссыль уже недоступен). А в данном случае тут всего один EXE файл от BlueSky, разве инструкция по нему остаётся той же?
Качайте пока ссылка действительная. Здесь всё есть абсолютно для установки.
